ASUS N53SV UMA
Notebook ASUS N53SV based on the platform ASUS N53SV. Another mod for remaking in UMA. When I came across this device myself, I did not find a working solution on the network to disable the discrete chip. And the instructions, where it was recommended to turn off the power to the chip, infuriated the cooling system. Therefore,
The reason I turned off the graphics. Under Windows 7, the drivers were installed, but it was not possible to use the discrete chip in any of the 3d applications. Even the GPU-Z utility crashed while trying to read the parameters of the NVIDIA chip. Under Windows 10, after installing the drivers on a discrete accelerator, the system issued a “blue screen” and did not start anymore. The famous "Code 43" in the device manager.
To disconnect, it was necessary to remove the resistor R7008. The chip power turned off automatically, no additional power-down actions are required. The cooling fan correctly adjusts the speed. Under Windows, the only graphics card from Intel was determined. We look at the photo for the article
ASUS N53SV UMA
ASUS N53SV UMA
- Attachments
- 20190611_141032.jpg (73.23 KiB) Viewed 522 times
- 20190611_134530.jpg (48.82 KiB) Viewed 522 times
- 20190611_134204.jpg (149.83 KiB) Viewed 522 times
